Golen 383 Damper wont line up
Old May 5, 2006 | 10:33 PM
playa7970's Avatar
Anything i should know i have a 94 z
Old May 5, 2006 | 10:49 PM
playa7970's Avatar
Re: Golen 383 Damper wont line up
will my 94 damper work with my new 383
Old May 6, 2006 | 01:10 AM
kingslam's Avatar
whoa wait! better check with golen on whats wrong there, your rotating assembly is balanced so dont put your old one on there!
Old May 6, 2006 | 07:28 AM
Jeff95TA's Avatar
But the harmonic balancer is zero balanced.
Old May 6, 2006 | 09:32 AM
playa7970's Avatar
well my mechanic called saying that i have a problem with the car and that the damper from a 94 doesnt have a key??
Old May 6, 2006 | 09:39 AM
cmroSS97's Avatar
call chad talk to him as he told me stock balancer is zero balance slide it on dont worry about position of arrow ( i always line it up though so that i know where tdc is) only reason you would need it to be keyed is if it were balanced to your rotating assembly (ie external balance) or with a blower so that you dont spin it on the snout of the crank
Old May 6, 2006 | 10:00 AM
Dave89IROC's Avatar
unless the golen assm. came with the key in the crank
Old May 6, 2006 | 10:19 AM
cmroSS97's Avatar
pop the key out then not a biggie
Old May 6, 2006 | 01:37 PM
playa7970's Avatar
Yea cuz it looks like from what my mechanic told me that theres a key on the crank thanks
Old May 6, 2006 | 01:49 PM
cmroSS97's Avatar
the stock crank has a keyway cut in it, well actually two: 1 of them has a key in it it is used to locate the timing chain sprocket onto the crank, The second outer most keyway does not have the key in it from the factory, the balancer is zero balanced from the factory thats probably why they didn,t put the keyway in b/c its orientation on the crank is irrelevant, they just install it w/ the pointer as a reference mark for TDC,with either #1 or #6 at TDC that pointer should be @ 12 o'clock(doesn't have to be i just like it for referernce when setting valve lash) Chad Golen told me he must have spun over 100 stock lt1 balancers on a balance and they all are zero balance, do make sure you have your flexplate/flywheel zero balanced
Hope this helps
Bill
Old May 6, 2006 | 07:23 PM
playa7970's Avatar
Thanks for the help i guess ill have to wait until monday until there open
Old May 6, 2006 | 07:39 PM
cmroSS97's Avatar
good luck w/ it chad is pretty good to deal with i should be firing up my golen engine next weekend
Drtryder
Apr 22, 2015 04:17 PM
cheapchevy
Apr 8, 2015 08:48 PM
drptop70ss
Mar 26, 2015 01:50 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
