gold roller rockers
Old May 4, 2005 | 01:23 AM
ruqwknf's Avatar
gold roller rockers
i just put my AFR heads on i am getting ready to put the roller rockers on to tighten down the first one but it seems like there is not enough clearance. i mean when i screw it on the top bolt it seems like 1 turn and it is at 0 lash could this be right. it does not look tight....
Old May 4, 2005 | 07:32 AM
Ken95Z28's Avatar
Re: gold roller rockers
There is a flat side and a round side where the nut screws down on the rocker arm make sure you have the flat side up. Also make sure you have the jam nut screw all the way up to the top.
Old May 5, 2005 | 01:27 AM
ruqwknf's Avatar
so how much clearance will there be as far as from it screwd on to the top of the stud?
Old May 5, 2005 | 05:03 AM
InsuranceGuy's Avatar
Have you rotated your motor to make sure each lifter is on the cams
base circle before installing the rocker?
Emil:93 Z
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
