Going to Replace the Starter
Old May 4, 2006 | 11:58 AM
jasonwinn's Avatar
It looks like I am going to end up replacing the starter on my car.
I did a search and it looks like I need to remove the transmission dust shield. I was wondernig if anyone has pictures or a tutorial on how to replace the starter? I was hoping shoebox would have a tutorial but no luck.
I am not very good at working on cars but I would love to be able to do this myself on the weekend instead of taking it to a shop. How many hours of work do you think it might be?
I forgot to mention on my other thread that I do have remote start, but even if the remote start didnt work, I should still be able to start with the key.
Old May 4, 2006 | 12:06 PM
robwin95z's Avatar
Re: Going to Replace the Starter
dude, once the car is up on jackstands or even ramps, you could replace it in like 15 minutes tops. two bolts. super easy. just remember what wires are connected to what terminal. i never removed any dust shield.
Old May 4, 2006 | 12:20 PM
jasonwinn's Avatar
Thanks! what i was reading made it sound alot harder.
Old May 4, 2006 | 12:32 PM
94Z28WP's Avatar
You'll probably need to remove the dust shield to make it easier... You might have to turn the starter in the opposite direction with the nose pointing up towards the engine and pull it down backwards... On my car it was a tight squeeze and I had to do it that way... I also had to unbolt the trans cooler line bracket near the motor mount so there was enough flex in the line to get it past it.
Old May 4, 2006 | 01:11 PM
Javier97Z28's Avatar
Moderator
You don't have to take off the tranny inspection cover. Two bolts, two wires, she comes right out.
Old May 4, 2006 | 01:54 PM
93formula350's Avatar
oh and definatly unplug your battery lol i didnt do that with mine and got a nice suprise
Old May 4, 2006 | 08:00 PM
matt65's Avatar
Go for it man, no big deal at all. Use good jackstands to securely keep her off the ground while you work (if you don't have a lift etc.)
If you get stuck, drop back by here.
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Feb 5, 2015 11:04 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
