Going to port my stock TB
Old Mar 18, 2008 | 01:53 AM
tspence45's Avatar
So, I found a deal on a stock TB, and for lack of better things to do, I think I'll buy it and port it. My only problem is, is I can't find any bigger throttle plates/blades to put in place of the stock ones. I want to find either some 52mm or 54mm blades, but I'm not having any luck at all. 3.125" would probably work, with porting it to 54mm, but, I'm having troubles finding blades that big too. The biggest I've found are 2" blades. Anyone know where I could get the right size throttle plates/blades?
Old Mar 18, 2008 | 08:55 AM
Kinsler will make you whatever you need:
http://www.kinsler.com/page--Home-Page--13.html
http://www.kinsler.com/Cat_31_Web_HT..._screen25.html
Good luck getting a 3.125" blade into a 54mm hole
Old Mar 18, 2008 | 09:00 AM
dangalla's Avatar
1 inch is 25.4 mm
Old Mar 18, 2008 | 12:15 PM
tspence45's Avatar
Whoops, I meant 2.125". lol. It was late. Thanks for the links.
Old Mar 18, 2008 | 06:21 PM
evilundisguised's Avatar
Are you planning on doing this by hand?
Old Mar 18, 2008 | 06:52 PM
tspence45's Avatar
I'm going to get a porting kit off summit and use a dremel tool.
Old Mar 18, 2008 | 07:14 PM
MeanGreen97Z's Avatar
It would probably be cheaper to buy a ported one off ebay for 169$.
Old Mar 18, 2008 | 08:06 PM
So you're going to use a dremel to create a perfectly round hole, perfectly true in position to the throttle blade mounting holes, and cylindrical enough so that they can freely rotate within?
That is what lathes and/or mills are for, but not dremels...
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
jj_burchiel
Mar 5, 2015 07:05 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
