Going to Get heads today Quick Question
Old Jun 23, 2003 | 08:42 AM
JOE96Z28SS's Avatar
I am going to get AFR 190 Street Heads. Would it be better to get the LT4 version and get an LT4 Intake. Or just Get the LT1 Heads??? Or can I just Modify My Intake??
Old Jun 23, 2003 | 08:53 AM
joeSS97's Avatar
Its a tough decision,I am debating the same thing.All depends on your goals.The Lt4's have a lot of potential.The 190 would be a little more street friendly.Just my thoughts.
Old Jun 23, 2003 | 09:04 AM
JOE96Z28SS's Avatar
Well Their Both 190 Street Heads, Is the LT4 Intake That Much Better??? Also I've heard that the LT1 Intake Can be Made to flow Better than the LT4. Lingenfelter does a LT4 Conversion if you send in a LT1 Core!! are the differences that minute? Basically is it worth the extra $$$
Old Jun 23, 2003 | 09:08 AM
joeSS97's Avatar
Pretty sure the LT4 is 195 cc.I dont know about the intakes,but I have a feeling it wouldnt make much difference.The LT4 is prettier.lol.If you are looking for max HP the LT4 is probably for you.It does flow better,especially at the higher lifts.Porting it more and it would be a monster.
Old Jun 23, 2003 | 09:34 AM
Gripenfelter's Avatar
The main restriction on LT1 motors are our intake manifolds.
Even if you get 275cfm@.550 lift, you'll still be restricted by whatever your intake port flows.
Old Jun 23, 2003 | 09:39 AM
JOE96Z28SS's Avatar
OK Does anyone have the GM Part Number for the LT4 Intake???
Old Jun 23, 2003 | 10:36 AM
got_hp?'s Avatar
i dunno the part number, but ive seen the lt4 intakes going for just over $200..........definetly worth it, since the AFRs cost the same whether its LT1 or LT4.
go LT4
Old Jun 23, 2003 | 11:21 AM
ltlhomer's Avatar
I think our intakes are pretty stout from the factory. In fact, I have a completely untouched intake manifold. All the head porters I asked said the intake would flow much more than my heads would be able to flow so it wasn't worth porting the manifold. BTW, my heads flow 260/190 @ .550" which isn't anything fantastic, but it is usually comparable to what most people get when their heads are ported.
Old Jun 23, 2003 | 12:50 PM
llafro's Avatar
Not to rain on your parade, but you can get really good flow out of a set of ported stock LT1 castings. I had Lloyd Elliott do a set of LT1 heads for me, and numerically they match up really well against the AFR 195 cc LT4 competition port heads that cost $2500. AFR's are better on the exhaust, but not THAT much. I paid $1150.
With a Comp XE 230/236 cam, I made 381 rwhp through SLP shorty headers. The LT1 heads are worth looking into.
In terms of AFR heads, I would go with the LT1 heads just so you can reuse your LT1 manifold. It flows more than the heads, and everyone I've talked to says that stock it's fine. That's why there's no real aftermarket replacement. The AFR LT1 heads flow about the same as the LT4 (see their website and compare the numbers). Usually you are better on a street engine staying with smaller cc intake runners so as to increase low-end torque and response.
BRAD
Old Jun 23, 2003 | 03:18 PM
JOE96Z28SS's Avatar
Yeah But I can get a set of AFR LT4 Heads for $1795.00 I have not seen anyone who will do my stock heads for $1500.00 or less. Not to say I'm sold on AFR's it's just the way I'm looking at it now is I can get NEW heads for 200 more OR having Nu-Tek do My heads. Maybe have my heads done and use the excess cash for Hydra Rev?
Old Jun 23, 2003 | 03:30 PM
Kreinmc's Avatar
Are you going with a little cam? I personally would get nothing smaller than the AFR 210 lt4's. When i get some nice heads i will most likely get the race ported 220 lt4's. I knew someone with the 195's and a hotcam and the car was pretty slow!
Old Jun 23, 2003 | 07:23 PM
got_hp?'s Avatar
you can definetly find people to do a great job on your LT1 heads for less than $1500.
combination motorsports (board sponsor)
phil at advancedinduction.com
lloyd elliot (do a search for his email)
they all are highly regarded on this forum.
those afr lt4 heads are expensive, and still need porting done to them to really make them worthwhile. so it will be alot more than 1795!
Old Jun 23, 2003 | 11:31 PM
JOE96Z28SS's Avatar
Wow, I had my mind made up!! I was Going to have myself some new Cyl Heads today!! I figured I'd Bounce it off ya and see if my plan was good!! Now I'm torn!! OK Looking at my setup, Where is my weakpoint now??? I definately am going to keep the rotating assembly stock for now Just to see how many miles I can rack up on it when I dissisembled it last winter it looked GREAT so I just left it alone so bottom end aside Where's my weakest link the lifters and pushrods are still stock. and I have a +/- $2000.00 Budget, I'm definately thinking heads but now I absolutely have no Idea. . . Please Help!!
Old Jun 24, 2003 | 09:26 AM
got_hp?'s Avatar
id get some hardened pushrods, and new lifters if those are the only things you havent replaced yet. that shouldnt cost you more than $250ish..............i got a set of barely used chromoly pushrods for $50! (normally $110ish).......or you can get brand new stuff......hardened pushrods are only $40ish, lifters $200ish.
then just decide who you want to do your heads.
i already recommended 3 choices who you can feel safe with, and will get great results.
you might as well get the whole package from them (bigger valves, new springs, etc). this will end up being about $1000-1500 depending on who you go with.
just remember, the power is in the heads (well most of it), so go with someone who has already proven they get good results and happy customers (ie those guys i recommended).
Old Jun 24, 2003 | 10:53 PM
JOE96Z28SS's Avatar
I like your plan As for bottom End I may Build it stronger after she blows (oR iF???) but I think I'll always keep it a 350. I have always liked the Higher compression So basically I'm looking for a set of heads that will run the best with a 350CID bottom and the LT4 Hotcam. I don't have any problem using higher octane fuel I may go true-dual and put some LT's on it but I really do a lot of highway use! I don't want to build a non-streetable machine I have AC and all the fixins inside with some occasional autocross and drag racing
