going to do cam wich do you suggest for my car (i have searched)
i dont plan on doing heads well any time soon and the hotcam i have ruled out i alresdy have 1.6rr im just confused on wich cam to go with i just dont understand all those numbers is there a cam between the cc305 and cc306
I agree with the entire LT4 set-up. Got it in my 1995 and it is totally streetable with enough lopp to get noticed. I could have gone bigger but I like the streetablitity of the car now. With Stage 2 heads and a cam I get almost 400 rwhp.
Unless you have emissions to deal with I would not put the 224/230 on a 114 LS when you start changing LSs on a cam you not only change overlap but the moment of opening and closing during the cycle are completely shifted. I would go the 224/230 or the 218/224 as ground with 1.6 rockers, you will not be dissapointed.
so the cc306 is bigger than 224/230 i need more top end
Originally posted by drewstealth
Well i do have emissions to worry about. I heard that the cc305 will pass on a 112 lsa but not the xe 224/230. So which do you think would provide more power, and would sound better.
I have a 224/230 and wouldn't go any smaller than that. I kinda wish I would have gone bigger, but it probably wouldn't help me much with stock heads. I was expecting it to lope, lose some low end, idle bad etc... It does none of that. This cam is very, very tame with a mail-order tune from madwolf. I saw people post about cam surge and drivablitly issues with bigger cams, but this thing is 100% as driveable as the stock cam. Most people probably wouldn't be able to tell the difference between the stock cam and this one untill they got on it. It feels much stronger up top, especially in the mid range(4-5.5k). I also don't feel any loss of low end, just a lot stronger top end.
to make the power you need on a cc306 you need to rev to 6500 rpms, which is kinda high for a high mile stock bottom end (in my opinion at least). That is why I chose the xe 230/236 112, it makes good tq by 2krpm, and by 3k you are in your seat good (max tq around 2500? w/ stock heads) and makes max rwhp @ 6200rpm max.
at least at 6200 w/ a fully upgraded valvetrain you should be fine.
cc306 guys, is 6500 high to rev it or is it fine?
Dec 1, 2014 08:08 AM
