Going carb with the LT1 few ?'s
Old Sep 6, 2004 | 10:50 PM
30thCamaroZ's Avatar
First off do you have to buy a special intake? If so can I have a link to that please. And I'm guessing if you do it's just so that you can retain the optispark instead of going to a distributor at the back. If I can do that then I'd just use any SB350 intake. Also will a B & M 144 roots type fit with some cutting to the cowl? I know it's going to be hard to get answers on this any help is appreciated.
Old Sep 6, 2004 | 11:42 PM
irishz28's Avatar
Re: Going carb with the LT1 few ?'s
i know edelbrock makes a carb intake for the lt1, as far as the supercharger, you got me pal.
Old Sep 7, 2004 | 09:37 AM
bski224's Avatar
Yes you will have to buy a special intake, you cant just get a small block intake for a 350 due to the LT1 heads and the bolt pattern. Go to gmpartsdirect.com they have the intake you will need at a GREAT price. As far as distributor goes you will need to block off exsisting hole with a plate that will also come with the intake manifold.
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
