going from a .842 lifter size to a .875 lifter
Old Sep 22, 2006 | 10:11 PM
WIDOMKR383's Avatar
what is the reason or is there any benifit in a solid roller engine?
Why do they do it in flat tappet engines?
Old Sep 22, 2006 | 10:19 PM
96capricemgr's Avatar
Re: going from a .842 lifter size to a .875 lifter
They do it on flat tappets because it lets them run a more aggressive lobe, the roller lifters we got stock are a big step beyond that already.
Old Sep 24, 2006 | 05:15 PM
matLT1's Avatar
By increasing the contact area of the lifter, there was less pressure on the surface of the lifter. The reason behind this is because Pressure=(Force/Area). Even if you still had the same cam profile (only applies to flat tappet), by increasing he contact area with a constant force the pressure will decrease. But like mentioned above, you are already better off with a roller cam.
Old Sep 24, 2006 | 07:01 PM
SStrokerAce's Avatar
Yes,
The benefit in a solid roller motor, or the reason I use them is that it makes my lifter bore indexing easier to do. You don't have to bush the block most times. You can also get some strength increase in the lifters doing this, but mostly for the lifter bore indexing is why I would do it.
Bret
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
