GMPP guide plates? Do the LT1's need these?
Old Feb 14, 2005 | 12:27 PM
vette40th's Avatar
My CNC cylinder heads have Comp Cams guide plates. I have heard these arent the right ones due to proper alignement of the pushrod to valve stem? IS this true, anyone run into any problems with the Comp CAms guide plates?
Old Feb 14, 2005 | 01:01 PM
SS MPSTR's Avatar
Re: GMPP guide plates? Do the LT1's need these?
I'm running Comp guide plates with 3/8" push rods, and they line up fine. I understand that with 5/16" push rods, there are alignment issues.
Old Feb 14, 2005 | 01:04 PM
vette40th's Avatar
I am running the 5/16 and did not know till I came to this site, that there is a issue with the LTx motors. I am getting the GMPP ones, and hopefuly this will help aligne them, as they are off a little. But a little could be a lot at High RPM.
Old Feb 14, 2005 | 01:45 PM
Fastbird93's Avatar
The LT1 has a .050 wider offset than the standard SBC. It could and has caused problems. The GMPP guideplate is the one that seems to work out the best.
PIC 1 GMPP Vs. Comp -- Thanks to whomever this picture came from.
PIC 2 GMPP Vs. Combination Motorsports -- Thanks to Shoebox
Old Feb 14, 2005 | 02:01 PM
vette40th's Avatar
Great Pics. Thanks
Old Feb 14, 2005 | 06:10 PM
12SCNDZ's Avatar
I lived this nightmate....COMP PLATES WON'T WORK ON AN LT1! Anyone who tries installing them SHOULD notice right from the start that something doesn't look right.
Frank
Old Feb 14, 2005 | 07:35 PM
vette40th's Avatar
Ordered the new plates from GMPP. Thanks guys/girls (just in case). Thanks
Old Feb 15, 2005 | 07:36 AM
Dave88LX's Avatar
Are you running Self-Align or Non-Self-Align rocker arms?
Old Feb 15, 2005 | 07:40 AM
groundpoundinlt's Avatar
i thought you didnt need guidplates unless you have NSA rockers
Old Feb 15, 2005 | 11:34 AM
"White Knight"'s Avatar
you are correct
Old Feb 15, 2005 | 11:49 AM
Dave88LX's Avatar
Jus' making sure, didn't see it specified in your original post.
Old Feb 15, 2005 | 10:01 PM
vette40th's Avatar
Crower Enduro Non Self Aligning 1.6 Stainless
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
alphaauto
Jan 23, 2015 07:42 AM
squinn
Aug 4, 2002 01:06 PM
