Gmmg Sound Clips
Old Jul 5, 2005 | 05:44 PM
  #31
94irocz's Avatar
Re: Gmmg Sound Clips
Originally Posted by xxsaint69x
hmm, might have to try that. Hopefully they do not eat up a lot of hp to run. Do you have any clips of your car?
Marcin
I have gmmg, lt's with a off road ypipe and yours sounds a lot different then mine. Does your 355 have a lot of compression in it or something. I wouldn't think 5ci would make that much difference in the sound of the car. I have a couple clips of mine racin down the road from inside and outside and a few at the track if you wanna check em out you can hit me up on aim.
Joe
Old Jul 5, 2005 | 08:16 PM
  #32
95RagtopTA's Avatar
GMMG are great systems almost got one myself until I found a used Borla system that I couldn't pass up . I suffered from similar rasp until I put THESE in--they really cut down on my rasp and popping. Pretty cheap fix and doesn't rob any HP....
Old Jul 5, 2005 | 09:30 PM
  #33
xxsaint69x's Avatar
Will have to try these..how do i install them?
Old Jul 6, 2005 | 12:23 AM
  #34
ZBLKHELLRZR's Avatar
That's what I was talking about....I just couldn't remember the name. You just have to take your I-pipe off OR drop the y-pipe and put one in each collector there.
Old Jul 6, 2005 | 10:39 PM
  #35
xxsaint69x's Avatar
they just stay in there?! eheh
Old Jul 7, 2005 | 08:07 PM
  #36
95RagtopTA's Avatar
The directions say to drill a hole through the colector and bolt them in . I didn't want to drill through my jethots so I VERY CAREFULLY bent out the tabs on each cone and hammered them in the collectors. I've had my Y-Pipe off several times and have noticed that they haven't moved. Hope they work for ya....
Old Jul 9, 2005 | 10:20 AM
  #37
xxsaint69x's Avatar
thats what i ended up doing. So far so good, i must say these cones helped a lot more then i thought they would. Ill post new video today.
Marcin
Old Jul 9, 2005 | 10:30 AM
  #38
lookingforwheels's Avatar
Marcin
Cool, I just ordered mine through a GP.
FredM
Exhaust System
Feb 8, 2016 02:10 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Nickster 7
Aug 27, 2015 10:12 PM
GT what?
Jul 14, 2015 10:17 PM
