gmmg question.
Old Nov 18, 2003 | 07:51 PM
C.Bachmann's Avatar
Question gmmg question.
will gmmg exhaust owners please answer a few ? 1 fit and finish of the exhaust? 2 how long did it take to get your system and 3 is the system free flowing or straight through as it appears? and 4 how loud is this system in the car? thank you for your time and help chris.
Old Nov 18, 2003 | 07:55 PM
will62085's Avatar
my freind has one on his ls1, sounds great...alot mellower than my long tubes/true duals...but sounds good...strait through chambered design...looks to be pretty high quality, i know gmmg makes good stuff
Old Nov 18, 2003 | 09:19 PM
Indy93Z28's Avatar
1. Finish and fit are awesome.
2. Took about 2 weeks.
3. Not sure exactly what you're asking. But it flows through the chambered mufflers.
4. It's not real loud inside the car if it's mostly stock. It gets much louder with a cam though
Old Nov 19, 2003 | 12:28 AM
C.Bachmann's Avatar
Question
indy 93 and all who answered thank you on ? # 3 i mean are there any restrictions on this system kind of like the stock system where there is 1 pipe in and 2 that exit that kind of distrupt flow unlike the borla which has a bypass. i was told through a shop that all catbacks flow about the same which is true but the borla with its bypass flows slightly more . i can see why, there is nothing to distrupt flow. i was wondering if there is any restriction in the chambered muffler on this system kind of like what corsa claims that they have a non restrictive muffler. any more info will be greatly helpful and thank you all once again. chris.
Old Nov 19, 2003 | 12:52 AM
Indy93Z28's Avatar
No it's not straight through it flows from the I-pipe through dual outlets. I doubt other systems outflow it by much if at all. Even with better flow numbers another system wouldn't dyno much higher if at all.
Nickster 7
Aug 27, 2015 10:12 PM
Latronaxe
Jul 20, 2015 12:00 PM
BLK1997Z28
May 7, 2015 03:01 PM
Mystery Z28
Oct 20, 2002 11:35 AM
sleeperZ96BT
Sep 4, 2002 08:26 PM
