GMMG - from an LS1?
Old Sep 9, 2004 | 11:17 AM
TobyZ28's Avatar
GMMG - from an LS1?
I'm able to get a good deal on a GMMG from someone from the LS1 board. Does anyone know if it will fit on my 95Z28? Will I need anything outside of the standard pieces to make it hook up? I have a single cat stock exhaust.
Old Sep 9, 2004 | 12:25 PM
1msfyter's Avatar
Re: GMMG - from an LS1?
You might need the "S" adapter. Any muffler shop can whip one up. The exhaust itself will fit on any 93-02 camaro. Shouldnt cost more than$75-100 to install.
Old Sep 9, 2004 | 12:26 PM
unvc92camarors's Avatar
it's going to be a little different
the cats on the ls1s hook back up to their i-pipe by use of a y-pipe
so the gmmg is going to start a little back of your cat
since you have the stock catback, all you have to do is measure and cut the stock i-pipe off where it will go into the gmmg
so basically, you're saving the "s" part of your pipe after the cat and cutting the rest of the i-pipe off
Old Sep 9, 2004 | 12:27 PM
nah, gmmg directs you to just use the stock one, it slides right into the gmmg - ask me how i know
Old Sep 9, 2004 | 02:00 PM
fesgali's Avatar
SLP sells a S pipe thats used with there loudmouth, it would probably work with the GMMG
Old Sep 10, 2004 | 01:30 PM
CLBHK's Avatar
Yep, part # 30045, and it works just fine. I just installed a GMMG on my 94 using the SLP adapter, rather than cutting up my stock exhaust (took it off in 1 piece). It also comes with the adapters to hang an LS1 exhaust, though those were redundant with the ones that came with the GMMG.
Old Sep 10, 2004 | 01:49 PM
man, i wish i would've known that when i was installing mine
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
Nickster 7
Aug 27, 2015 10:12 PM
