GM Performance #12370839 ROLLER ROCKERS
http://store.summitracing.com/partde...9&autoview=sku
What would you think a used set of these would be worth? They are in great condition. Are they any good also?
I'm running them on a cc306 stroker car and they are holding up great. Nice and fairly quite as well. From what I understand Crane makes them but I could be wrong. Either way they are maxed out a .575 lift if you want to put that in your description. Should be good for $100-$200 used.
I'm curious why this is. Not doubting your info, but doesn't the rocker nut determine how long the rocker will hold its preload? I mean, do they have bearing issues or something?
Also with a stronger spring pay attention to how much clearance the shaft of the rocker has around the stud too much wiggle and it can eat on your stud and eventually break, especially if your geometry is a little out of wack.
oldschool
Feb 9, 2016 09:21 PM
