Gm part # for oil pressure switch for 97 ss
Old Mar 18, 2018 | 03:10 PM
cam2z's Avatar
Does anyone know the gm part # for the oil pressure switch that is located on the back of the intake manifold. This is for 1997 lt1. Thanks
Old Mar 18, 2018 | 03:28 PM
Chimera96's Avatar
Re: Gm part # for oil pressure switch for 97 ss
may be here, courtesy of shbox.com
Old Mar 18, 2018 | 06:47 PM
1993-1997 F-Body Part Number Collection
It's way down toward the bottom of the list.
Old Mar 18, 2018 | 09:26 PM
cam2z's Avatar
What is normal oil pressure for a lt1. On cold startup I get around 40 psi and hot idle I say 10-15 psi.
Old Mar 18, 2018 | 09:38 PM
Fairly normal for an LT1 engine with medium/high miles on it, assuming 5W-30, or 10W-30 oil. New LT1 engine would be 30 PSI fully warmed up, 650-800 RPM idle.
Old Mar 18, 2018 | 11:33 PM
cam2z's Avatar
There was 10w30 in the car originally i switched to 10w40 and seen no difference in change in pressure. That has me to believe it might be the pressure switch going bad. Car has 114,000 miles on it.
moondance
Apr 18, 2010 12:03 PM
nonojoe66
Dec 22, 2004 10:11 PM
craigffb
N2O Tech
15
Mar 21, 2003 03:08 PM
