Gm 847 Need Help???
Old Dec 23, 2006 | 07:57 PM
osolow's Avatar
Gm 847 Need Help???
Is this a good cam for my setup??? I have a 6'' 381 with ported heads( flow like le3 heads). I have all the bolt ons and i will be spraying. What exactly are the specs on the 847??? I was going to get a le4 cam but now loyd will not sell me 1 by it self. Thanks for the help.
Old Dec 23, 2006 | 08:47 PM
osolow's Avatar
This will be a weekend cruiser. Is this cam to big or to small??? What would you recomend?
Old Dec 23, 2006 | 08:48 PM
speed_demon24's Avatar
PM sstrokerace I have a custom cam from him in the mail.
Old Dec 23, 2006 | 10:47 PM
maro z28's Avatar
It's not too big, especially for a larger than stock cube engine. http://web.camaross.com/forums/showt...ht=gm847+specs
Read this forum.
Old Dec 23, 2006 | 10:59 PM
seawolf06's Avatar
Cam will depend on a lot more than your displacement. Check your compression as well. You can try to call Comp about a cam, but I'd recommend Bret Bauer or Allan at Futral to pick one out for you.
Old Dec 24, 2006 | 02:03 AM
FryedClutch's Avatar
so far i have had experiance with the cc 306 the cc503 hotcam and the 847
byfar my fav is the 847 you do notice(on a stock cube motor) a lack of low end on a 6speed but it pulls extreamly hard from 3 grand on up it was extremely fun to drive with that cam
the minimum i would go on your motor is a cc306 or similar sized on a stock cube auto it drives near stock (IMO) with a decent stall no noticable cam surge and real nice power all over
Old Dec 24, 2006 | 05:45 AM
med_reject's Avatar
847 on a manual surges like a bitch on stock cubes! Hope you know a damn good programmer. It makes awesome power
Old Dec 24, 2006 | 01:40 PM
osolow's Avatar
I think i will talk to Brett about a custom grind. I was wondering if stock replacement lifters will be ok, or do i need comp or????? What lifters are you running???
Old Dec 24, 2006 | 01:54 PM
SS RRR's Avatar
depends on the tune. mine doesn't surge unless it's below 1500rpm.
sleeperZ96BT
Sep 9, 2015 08:28 AM
Metlegleo
Mar 15, 2005 11:16 PM
badblackta
Mar 10, 2004 09:18 AM
Camaro_Maniac63
Feb 9, 2004 04:26 PM
Mystic97Z
Dec 16, 2003 05:00 PM
