"Ghetto" Leakdown Question
I don't have a real leakdown tester, but I do have a compressor. I've been fighting an oil leak that is coming from in between the heads and the block. I'm about to pull the heads but before I do I'm pumping compressed air into the cylinders using a valve hold down fitting. I can hear air leaking into the crankase at just about any pressure. Using the guage on my compressor it slowly leaks out even at as low as this thing will read. Understand that it's not coming out very fast, I would estimate at less than 5psi so far on the cylinders I've checked. I'm really just testing to be sure that my valves are sealing, cause I'm not burning any oil and the plugs look fine, if anything they look slightly lean, so no oil in the cylinder.
At any rate is some leakage past the rings normal? Or should I just pull the whole thing and rebuild it. Not really an option that I care to take on at the moment. Car has about 90k on it and is running great, just the oil leak thing has been driving me nuts.
Thanks and sorry for the long post.
Re: "Ghetto" Leakdown Question
Originally Posted by shoebox
Some leakage past the rings is normal. It is the rate of leakage that is important. That is why you need the proper leakdown tester.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
