geyser = blown head gasket?
Old Aug 19, 2006 | 11:48 PM
j0n's Avatar
j0n
I just got my new(ish) engine running(fresh bottom end i rebuilt the whole top end) with an electric water pump. the engine overheats real fast and at ~230* on the guage i got a geyser about 1.5-2 feet out of the radiator.
is this definately a blown head gasket? and is a leakdown test the only way to know?
Old Aug 19, 2006 | 11:53 PM
95LT1conv's Avatar
Re: geyser = blown head gasket?
sounds like your thermostat is not opening
Old Aug 19, 2006 | 11:57 PM
j0n's Avatar
j0n
on t-stat #2 right now...opens at 180* in a pot of water
Old Aug 20, 2006 | 12:03 AM
95LT1conv's Avatar
is the WP installed in the housing correctly? i have heard of the propellers being installed backwards reversing the flow.
Old Aug 20, 2006 | 12:04 AM
j0n's Avatar
j0n
propellers dont get installed backwards the wiring gets mixed up...my wiring is all good...triple checked it
Old Aug 20, 2006 | 12:10 AM
95LT1conv's Avatar
im sure youve probably checked all the obvious stuff just suggestionsim sure youre right about the wires but i have read on here that someone suggested what i said. maybe they were as new to the EWP as i am. this only happens when the temp gets to 230 and not all the time?
Old Aug 20, 2006 | 12:18 AM
j0n's Avatar
j0n
correct
Old Aug 20, 2006 | 12:27 AM
95LT1conv's Avatar
disconnect the coil and do a commpression test
Old Aug 20, 2006 | 01:02 AM
j0n's Avatar
j0n
drained the oil...its got coolant in it...now what?
Old Aug 20, 2006 | 07:10 AM
Kevin Blown 95 TA's Avatar
You get to pull the head(s).
Give us some details of your build - maybe we can figure out what went wrong and save you a headache next time around.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
