getting rid of water pump driveshaft
Old Jan 18, 2004 | 08:24 PM
  #16
30thannZ28's Avatar
yeah, I have the intake manifold and the heads and the timing cover off. I want to plug the actual hole in the block. So you just left the hole open? Isn't that going to have a long term negative effect on the motor? Will letting ALL that extra oil into the timing chain area make a positive or negative difference in the longevity of the motor?
Good posts, please, more opinions.
Old Jan 18, 2004 | 08:54 PM
  #17
gb95zconv's Avatar
My engine biulder said it wouldnt be a problem....but It sure wouldnt hurt to plug it either. I may do that when I swap cams next week.
Old Jan 19, 2004 | 11:43 PM
  #18
30thannZ28's Avatar
Well, I think I have it figured out, but one last question. I'm going to put a freeze plug in the timing cover, and obviously in the waterpump housing, but I will have to remove the waterpump driveshaft because of my cloyes true double roller set, right? That's what I was told. It won't clear otherwise. can anyone with a cloyes set and a CSI or meziere please confirm this???
Old Jan 19, 2004 | 11:52 PM
  #19
AsianSensation's Avatar
FWIW, I removed the wp drive and did not put a freeze plug on on the block leading to the lifter valley. No problems as of yet.
Old Jan 20, 2004 | 12:13 AM
  #20
DrivinSidewayz's Avatar
can you replace the WP DS seal in the timing cover without removing the timing cover?
Old Jan 20, 2004 | 12:18 AM
  #21
30thannZ28's Avatar
drivin sidewayz, I'm not 100% sure, but from experience I'd say no. Not safely at least. You have to kind of use a mallet and hammer those seals in, and also hammer 'em out. So my guess is no. Good luck though! Let us know how it goes.
Old Jan 20, 2004 | 05:38 AM
  #22
Mtrhds94Z's Avatar
Yes
In fact it's probably the better way to do it..
Some people put TC on then the WP seal in..
It's hard to get right... buy 2!
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
