Getting ready to rebuild
Old Mar 8, 2009 | 11:56 PM
green96ta's Avatar
ok im getting ready to rebuild the fireturd. all mods are listed in teh sig. im thinking about adding a 100 shot later on. this is why i bought forged pistons. okay i bought the forged speedpros that come in the kit with the rings and all that good stuff. that is the only part of the rotating assembly that i am going to change. i wil have the stock crank and rods re worked. i will be boring it over .030. that and the pistons are the only things changing besides the bearings and all that good stuff. i might do splayed 4 bolt mains. so my question is...will i have to have the rotating assebly balanced if im only changing the pistons? thanks for the help. and im sure the stock crank will handle the n/a hp that ill have plus a 100-150 shot. if im wrong on that please correct me so that i can get a better crank and or rods.
Old Mar 9, 2009 | 09:27 AM
camarobird92's Avatar
You have to balance it since you changed pistons. I'm sure the forged pistons are a different weight than stockers.
Old Mar 9, 2009 | 09:54 AM
BLKOUTZ28's Avatar
Due to the new forged pistons weight difference, balancing is needed. 4 bolt splayed is not needed but it is not a bad idea. I could not afford it this time around but I will do that when I build the 383 next year. Machine work cost me $1,120.00 today on top of $3,000.00 in parts.
Old Mar 9, 2009 | 02:13 PM
DAVE00's Avatar
Needs to be balanced as they weigh different - as stated above.
Jeff1904
Jun 5, 2016 05:00 PM
LT14LIFE
Nov 15, 2015 06:22 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
ChrisFrez
Sep 9, 2015 06:52 AM
