Getting Off the Flywheel?
Old Mar 13, 2004 | 09:59 PM
lt1_forever's Avatar
So i'm all the way to taking the flywheel off in my clutch project, when i ran into a little problem. The flywheel won't come off. I'm using direction i got off brent94z web page and the guy said that it should come off farely easily. Well i can tell you that isn't the case, i had a 2 foot breaker bar on there and the thing wouldn't move at all. So i put WD-40 on it and Dura Lube and havn't tired seens then. So my question is, is there some kinda trick to getting this off or do you just need to wrench the crap out of it? Also has anybody else had this problem and what did you do about it?
Old Mar 13, 2004 | 10:12 PM
Bud M's Avatar
Mine came off easily after removing the 6 flywheel bolts
Old Mar 13, 2004 | 10:19 PM
well see that is the problem the bolts won't come off.
Old Mar 13, 2004 | 10:55 PM
JONEZ_Z's Avatar
Use a half inch impact.
Old Mar 13, 2004 | 11:36 PM
Are you turning them the correct direction? Had to ask.
Old Mar 13, 2004 | 11:46 PM
zx1216's Avatar
put a little muscle into it i got mine off with a 1 foot 1/2 inch rachet, i think the torque for the flywheel bolts is around 70 lb ft. other wise try an impact wrench.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
