Throwout bearing went, clutch forks jammed forward, what do I do?
Old Mar 13, 2004 | 11:32 PM
meengreen 94z's Avatar
My throwout bearing apparently went out. I tried to drop the transmission, but it wont slide back from the bellhousing. The clutch fork is jammed forward. Im going to disconnect the bellhousing bolts from the block tomorrow and see if I can wiggle it free but I thought Id ask if anyone has any tips ?
Old Mar 13, 2004 | 11:53 PM
zx1216's Avatar
did you take the slave cylinder off? I dont see how it could be jammed? There are 8 bolts total holding the trany to the bellhousing, there is a bolt on the top on each side that you can't really see, maybe u didn't get these? just throwin out ideas
Old Mar 14, 2004 | 12:32 AM
I have all 8 bolts off. Normally when you take off the slave cylinder and fork cover, the fork is revealed. You slide the tranny out a couple inches and disconnect the nut on the clutch fork, pull it off the throwout bearing and the transmission slides out. Well the clutch fork is pushed all the way in, as it would if it were pulling the pressure plate back. The transmission doesnt want to budge in any direction.
Old Mar 14, 2004 | 12:35 AM
zx1216's Avatar
hmm, thats weird, idk man i guess try to pull the bellhousing off the motor, btw you don't have to unbolt the fork, you can just pull it off the t o bearing.
Old Mar 14, 2004 | 12:39 AM
Thanks for the help, hopefully Ill figure it out in the morning
MyfateZ28
Jun 19, 2015 03:42 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 14, 2002 08:22 PM
