getting my 383. what's needed?
Old Nov 8, 2011 | 11:14 PM
  #16
henryz28's Avatar
Re: getting my 383. what's needed?
If you are on a budget build something like this http://www.ellweinengines.com/Ellwei...Kit/355Kit.htm.
Old Nov 9, 2011 | 03:12 AM
  #17
ussj4brolli's Avatar
Don't think there are any rebuild shops local here in or around reno Nevada.
Old Nov 9, 2011 | 03:28 AM
  #18
Bersaglieri's Avatar
Sacramento is 2 hours away and has plenty of shops along with many other areas of California.
-Dustin-
Old Nov 10, 2011 | 01:29 PM
  #19
Got some more information written down.
Federal mogal (hyper I believe) pistons, coated.
hastings rings.
New scat crank
Pioneer lifters
Felpro gaskets
Sealed power valves
Melling double roller timing chain
Clevite 77 bearings.
Just some things he wrote down for me.
Now, my secret on pricing....
Engine authority is motorworks too. Same engines from autozone, same place I manage, same place a co owner works....see why its so cheap for me?
Old Nov 10, 2011 | 05:13 PM
  #20
96capricemgr's Avatar
So no matter what those of us with experience say you have decided?
Old Nov 10, 2011 | 05:33 PM
  #21
Down priced from a 3300 block? Everyone is all about the price. It get a huge discounted price.still shopping around but seems to be the best deal so far.
Will check Sacramento too. This isn't happening until tax time, so Feb.
Old Nov 10, 2011 | 06:06 PM
  #22
RamAir95TA's Avatar
We really need a facepalm smiley.
What's the point in posting if you're not going to take anyone's advice?
Old Nov 10, 2011 | 06:18 PM
  #23
Ask and you shall receive.
Go fur it dood! Autozone makes **** everything, but I'm sure their crate motors are real pantie-droppas! Especially with those secret squirrel prices you're getting.
-Dustin-
Old Nov 10, 2011 | 06:24 PM
  #24
8cylinders>4's Avatar
Hmm double roller huh? They going to do the required mods to run one with a 94 engine? are they going to buy you a distributor if it comes with a later timing cover? Is it going to come with the correct cam to drive your distributor, if your motor is a 94 it would be a splined drive, Are they going to buy you an electric water pump since you cant drive the water pump without a factory style timing set, Do they realize a factory timing set is more expensive than a cheap double roller?
Seeing that listed makes me believe the pricing isn't for an LT1, maybe a 70 LT-1
Old Nov 10, 2011 | 08:56 PM
  #25
$3300 is approaching what one would expect to pay for a decent SHORTBLOCK, not a whole engine.
Old Nov 11, 2011 | 12:16 AM
  #26
I'm giving them my complete engine. Heads tb all the way to the oil pan and valve covers. They rebuilding it all, giving me different chrome valve covers new pan etc. Since I hear all these bad things I will be having a sit down with tom and his kid for a complete part number run down. This isn't happening until Feb. I haveanother camaro with the 95 lt1 extra, but 4 hours away in the other camaro.
Old Nov 11, 2011 | 02:04 AM
  #27
henryz28's Avatar
If they are rebuilding it, why can't you buy your own parts and have them do the machine work and install your parts. The best way for you to go would be buy your own parts then have a good shop do the labor.
Old Nov 11, 2011 | 07:29 AM
  #28
bw_hunter's Avatar
Read post #8 they don't rebuild anything...they're a broker.
It looks like the OP had already reached a decision when he first posted and was really looking for validation which didn't happen. As to the exact question originally asked...everything removed has to go back on the replacement engine. You'll only really need bigger injectors and a tune. Even your stock exhaust it'll bolt right on. It's not a good decision but certainly in keeping with those already taken....
Old Nov 11, 2011 | 08:54 AM
  #29
I was not including the cost of cores.
So they want to give you new valves for no reason, new oilpan for no reason, new valvecovers that will likely interfere with the alternator for no reason.
Far as those of us who know what we are talking about see you just keep making this look WORSE.
Old Nov 11, 2011 | 09:22 AM
  #30
Lt1son's Avatar
Well id stay away if i were you just as everyone else had mentioned. I just had a 355 built and a friend of mine who runs his own machine shop did all the work and parts pricing for me. And even with "friends discount" on parts and labor still ran me around $2000 for lower end alone and that was with me helping. But i will be able to sleep at night and know i can turn the key with no worries..... My take on it is do it once and right. And FYI most companies you call give you a standard 350 or sbc kit. I had to piece mine together because i could not get a "lt1 rebuild kit"... someone correct me if im wrong. But good luck
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
