Getting my 355 Rebuilt Questions REgards to BLOWER??
Old Nov 27, 2005 | 06:37 PM
LT1CST's Avatar
Hey Fbods.
Im getting my Fbody rebuilt. Just getting the bearings redone Since I blew them out. When I get my Motor done. IM thinking of putting a blower on it. The pistons it has are Forged Probed pistons. MY engine builder says that the compression is about 10:1. is that going to be OK for a SuperCharger. I know I cant go TO HIGH on boost Ill blow the heads off. But What PSI? can I run on a 10:1 compression LT1
CHris
Old Dec 28, 2005 | 11:41 AM
pillagenburn's Avatar
Re: Getting my 355 Rebuilt Questions REgards to BLOWER??
8-9:1 compression, hogged out heads (think LE2 for superchargers with blower custom cam)
at very least forged pistons/rods, forged crank if possible
1.6 rockers, LT4 timing set, probably upgraded radiator... basically all bolt-ons and run like 8lbs...
LT1 would probably end up being a better FI motor than aluminum LS1 (5-bolts around each cylinder, LT1 is iron etc.)
might wanna make it a 4-bolt too...
edit: if your engine builder says comp is 10:1 that's too high.... may consider increasing the cc size on the head combustion chambers (porting). This might get you to the 9:1 you need... plus a thicker head gasket possibly?
btw, how much are you paying for all of this? machine shops around here want to ream you without lube for labor costs
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
LT1runner
33
Jul 24, 2002 01:19 PM
