getting EGR and AIR programmed out? removing AIR pump?
Does PCMforless allow to program out EGR and AIR? If so, has anyone verified that it 'fools' emissions inspection machines? Not a sniffer, just where they plug into your PCM and get readings? Also, does anyone here know how much the AIR pump weighs? Could i just use o2 simms and remove the AIR pump, and that would satisfy the AIR requirement?
thanks!
thanks!
So....
So basically that means that the computer doing the emissions testing will know the EGR and AIR are removed? Or, the emissions computer won't see a code, so it'll assume its working? hehe - is that about right?
thanks!
thanks!
Well Do they not do a visual inspection? If so it doesn't matter what the computer is saying you'll be busted very quickly when they see your EGR ports are bolted up, and also if you get rid of the air pump I have heard to gut the Cat, or it will clog up.
no visual inspections....
No visual inspections, but if they obviously see the AIR redirection tubing torn out, and it still "passes" the test, they probably won't say anything.... im in Gwinnett County, Georgia
later..
later..
Re: I have ODBII...
Originally posted by pillagenburn
I have ODBII ..... i dont get the sniffer test hehe
i think they just check to see if its throwing codes, not sure tho....
thanks
thanks
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
CamaroZBoy
Sep 9, 2002 10:33 AM
ReznorZ28
Aug 27, 2002 03:53 PM
