Getting code: Quad control module. Need help.
Ok i recently installed a LT1 into my 99 s10 and im getting a service engine soon light (go figure) and it is the air pump, and the quad control module. The air pump was my fault for not telling Ion to delete it but what is the quad control module. I know it has something to do with the tranny and 4th gear but can someone explain to me more specifically?
Re: Getting code: Quad control module. Need help.
I know on the 93's if you remove your Air Pump and EGR Solenoid you will get quad driver module faults. You need to get a new tune with the Air pump and emisions stuff removed.
Henson071
Aug 4, 2015 09:32 AM
Noct
Jul 14, 2015 01:18 AM
