Getting the CAI actual cold air
Old Jan 28, 2003 | 05:27 PM
MeefZ28's Avatar
I installed my K&N CAI on my (new) 97Z today and as you know the filter hangs down below in the lower left compartment.
Though the compartment isnt airtight by any means, does the CAI get enough cold air at that location to achieve max performance?
I've heard of some people cutting spaces in their wheel well to allow cold air to get in the compartment, but I don't want to do this because I wouldnt want to mess up the filter if it rained or something.
What are yall's thoughts on this. Thanks,
Jay
Old Jan 28, 2003 | 05:32 PM
Greasepunk's Avatar
Unless you drive through deep puddles I dont think it would mess it up any worse than when it regularly rains. I have functional ram air and dont have problems when it's raining and I'm pretty much forcing water onto my filter when I'm cruisin.
Old Jan 28, 2003 | 05:37 PM
chesee48's Avatar
yea i have the cut out piece by the air damn with a piece that helps direct it in ( although it fell off) i have another one i bought. u can pick one up at any hardware store.
(thanks eddie for it)
Old Jan 28, 2003 | 07:45 PM
chevroletfreak's Avatar
Mine has been wide open for 2 years. No problems at all.
Old Jan 28, 2003 | 08:07 PM
Robbie's Avatar
I made a scoop for mine about 1 or so years ago. I just cut the plastic thats directly under the CAI and screwed a tin wedge shaped scoop there. I drive with it open all the time. Does tend to dirty up the engine bay more. How long has Rksport forums been down? I stop going there as much and when i went to go back it was shut down.
Old Jan 28, 2003 | 08:16 PM
psychocabbage's Avatar
mine had a scoop.. it was ok.. I off set it and did not mess with the air dam.. it worked fine.. car had decent power.. I had the SLP CAI kit on mine..
Old Jan 29, 2003 | 01:09 AM
MeefZ28's Avatar
So did yall notice any additional increase by adding the scoops/spaces than w/ the regular CAI???
I'm tryng to decide if cutting holes or adding a "CAI air dam" is worthwhile. Thanks,
Jay
Old Jan 29, 2003 | 02:39 AM
bunker's Avatar
never found any advantages in doing so, if any, there are more disadvantages like dirt etc... not worth the risk, if not the motor, then the MAF always gets it.
Old Jun 4, 2003 | 08:28 PM
scyzoryk's Avatar
I did a home made scoop under the Cai and I fu*ked up my motor (water sucked up to cylinders and destroyed my connecting rods). If you drive in rain-don't do it!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Britbilly
Jan 7, 2015 08:49 PM
