Gen 1 Question
Old Feb 20, 2006 | 10:06 PM
c0rey's Avatar
Gen 1 Question
Well after trashing everything in the bottom end of my lt1 block and taking out the block. I have been researching and reseaching and still need a couple answers. I have a reg gen 1 sbc bottom end sitting here. I am trying to figure out how in the hell to get my lt1 topend on it. Here is a list of questions for the experts.
Are the heads and direct swap?
I know I need a electric water pump.
With the accessory bracket from a lt1 bolt up to a gen 1 block with lt1 heads?
How can I internal balance the bottom end so I can run a lt1 balancer hub?
Will I be able to modify a gen 1 cam to have a cam dowel on it?
Anything else i am forgetting let me know. I want a lt1 topend of a gen 1 bottom end.
Old Feb 20, 2006 | 10:24 PM
FastZinTennessee's Avatar
Re: Gen 1 Question
They will bolt on, but the cooling passages are different so it's a no-go.
I believe it would.
The LT1 cam is simply a standard small block cam with a longer dowel pin.
You're starting off this project all wrong. While parts can be modified, usually it ends up being someone chasing horsepower and converting gen I heads to the LT1 block, this is way beyond the scope, and way beyond being worthwhile money-wise from a basic rebuild standpoint. How much money do you have available to get this motor going again?
Old Feb 20, 2006 | 11:51 PM
Re: Gen 1 Question
You can't use the LT1 fuel injection without the Opti, and you can't put the Opti on a Gen 1 block, at least not without inventing the conversion for the front of the block. Someone has mounted a distributor in the conventional position and managed to adapt the Opti optical sensor.
Old Feb 21, 2006 | 12:59 AM
MachinistOne's Avatar
Re: Gen 1 Question
That's only true if he has a factory roller cam block, otherwise the snout of the cam is diferent, and does not use a retainer plate.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
