Geeze am I gonna have to retorque the whole engine???
Old Nov 26, 2003 | 09:06 PM
S.J.S.'s Avatar
K guys... my stroker is almost broken in with 469 miles on it. I just looked under the car and saw oil on the ground. I put the car on ramps and found oil all over the bottom of the chain cover. I was so bummed. Everything has been perfect. The I look and there is oil on my Canton pan. I wiped it all off and found the oil to be coming from my reluctor ring sensor...screw was loose...hopefully that was it. Also my oil level sensor on the pan was loose. I remember tightening both of them. I'm wondering all you guys..... should I go over the entire motor?????
Old Nov 26, 2003 | 09:09 PM
jasons93z's Avatar
That really sucks I wouldnt go and retorque every bolt though.
Old Nov 26, 2003 | 10:47 PM
OBE1 95Z28's Avatar
If it continues to leak, pick-up so oil dye and a black light. This really helped tracking down a leak in my friend's 96 TA...turned out to be the timing chain cover gasket...that was fun to replace!
Old Nov 27, 2003 | 08:30 AM
S.J.S.'s Avatar
well just got home and the leak is still there. I don't know where its coming from. Aint the gasket though. Looks like on e of the seals or something. This blows.
Old Nov 27, 2003 | 09:25 AM
gb95zconv's Avatar
Did you replace the WP drive seal ?....that one seems to be a common problem.
Old Nov 27, 2003 | 07:19 PM
S.J.S.'s Avatar
I just built my motor, been in only 500 miles. Everything new.
Old Nov 27, 2003 | 07:23 PM
InjectedSS's Avatar
got a thousand bucks that say's you didn't get the waterpump seal on the right way
Old Dec 28, 2003 | 10:27 AM
Van5150's Avatar
SJS, did you get this oil leak fixed? If so where was it? Did you try the black light ?
Old Dec 28, 2003 | 11:25 PM
S.J.S.'s Avatar
Its the Opti seal and it only drips like a couple drop everyday so I said screw it. It couple be the waterpump seal but all the oil is around the opti and not the waterpump so I think its that. Either way I aint pulling the pan just for that.
Old Dec 29, 2003 | 07:51 AM
LameRandomName's Avatar
Get the dye!
Confirm the location of the leak so that before you decide to ignore it, you know exactly what you are ignoring.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
ModdedNerd
Dec 18, 2014 10:52 PM
Snoman73
Nov 17, 2014 07:22 PM
Duke
Jul 31, 2002 05:13 PM
