View Poll Results: Gears or RR?
4.10 Gears
9
64.29%
3.90 Gears
21.43%
Roller Rockers
14.29%
Voters: 14. You may not vote on this poll
Gears or Roller Rockers?
Old Mar 27, 2008 | 12:49 AM
Mortify's Avatar
I have just enough for Gears or Roller Rockers for my car, I was either between 3.90 or 4.10s, its a m6 with a m29 tranny so the ratios are slightly different than 94-97.. and I have 3.23:1 final gear atm. Thanks for your opinions!
Edit - I have LTs, Mufflex ORY, Magnaflow catback, Moroso CAI and PCM4Less Tune
Old Mar 27, 2008 | 12:58 AM
LT1BanditTA95's Avatar
[QUOTE=Mortify;5272564]I have just enough for Gears or Roller Rockers for my car, I was either between 3.90 or 4.10s, its a m6 with a m29 tranny so the ratios are slightly different than 94-97.. and I have 3.23:1 final gear atm. Thanks for your opinions!
Edit - I have LTs, Mufflex ORY, Magnaflow catback, Moroso CAI and PCM4Less Tune[/QUOTE
Well my question to you is- Do you have the ability/tools to install the gears yourself? If so I would go with the 4.10s first... If not then I would probly do the rolerrockers assuming you will do them youself...
Old Mar 27, 2008 | 01:50 AM
ss.slp.ls1's Avatar
First of all, with an M6, if gears are the choice, don't waste your time with anything less than 4.10's. My choice, gears all the way, you will feel it more than rockers.
Old Mar 27, 2008 | 07:17 AM
95firehawk's Avatar
Definately 4.10's.
Old Mar 27, 2008 | 07:48 AM
2000GTP's Avatar
I would probably opt for the gears as well.
Old Mar 27, 2008 | 07:52 AM
dangalla's Avatar
i think everyone is going to tell you gears, but dont forget you are going to need a tune to correct speedometer
Old Mar 27, 2008 | 09:11 AM
My Red 93Z-28's Avatar
You can't correct the speedometer with a tune on the '93 cars. The autos you can fix, but to correct the m6, you have to buy the Dakota Digital box.
I vote gears as well, I have an m29 too, but I have 3.73s in the back
FWIW, here are the gear ratios:
GR - M28 -- M29 -- 94+
1 -- 3.36 -- 2.97 -- 2.66
2 -- 2.07 -- 2.07 -- 1.78
3 -- 1.35 -- 1.43 -- 1.30
4 -- 1.00 -- 1.00 -- 1.00
5 -- 0.80 -- 0.80 -- 0.74
6 -- 0.62 -- 0.62 -- 0.50
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
