are gears necessary w/ heads/cam?
when putting heads/cam in a lt1 car, 6-speed with factory 3:42 gears,,it is a necessity to step up to 3:73's or 4:10's ?
if i'm trapping about 115 mph or so in the 1/4, i'll be in 5th gear with anything higher than 3:42 gears right?
i was just wondering,, i'd like to get 4:10's but i don't want my car to run out of steam after like 90 mph..
You use the gears for the set up you have..
For instance I have a heads/cam LT1 with SS 17x9 rims.
On the back i run Nitto 275/40/17 drag radials.
And it spins them over in the higher rpms.
I have 3.42's... if i were to switch to 4.10's i wouldnt get any faster because my tires would just spin..
16x8 rim with 245/50/16's drag radial will stick better than a lower profile tire like mine. Do your H/C then decide if you can benefit from gearing...
ChrisFrez
Mar 22, 2015 09:12 AM
F(ast)-body
Feb 26, 2003 09:05 AM
