View Poll Results: Which gears are the best/strongest?
Motive/GM
13
61.90%
Richmond
28.57%
Auburn
0%
Anything else
9.52%
Voters: 21. You may not vote on this poll
Which gears are the best in your opinions?
Old Apr 7, 2003 | 04:29 PM
Smokn '94 Z's Avatar
Question Which gears are the best in your opinions?
Motives/Gm
Richmond
Auburn
Anything else
Old Apr 7, 2003 | 06:47 PM
Dragon Racing's Avatar
From everything that i have ever heard, GM/Motive gears are the best gears to go with.
Old Apr 7, 2003 | 06:56 PM
chesee48's Avatar
i made my vote...
Are u going with 4.10's now??
Old Apr 7, 2003 | 07:55 PM
MYT30TH's Avatar
I recently had GM 4:10's installed ,and they are very quiet
Old Apr 7, 2003 | 08:00 PM
Haskin Z28's Avatar
well richmonds are the strongest, and your 10 bolt is one weak motha...so do you want quiet or do you want strength?
Old Apr 7, 2003 | 08:21 PM
LimitedEd1LE's Avatar
Yea the Richmond gears are a race cut gear, where as the GM Motive gears are not. The Richmond's will be much louder since they have straighter teeth. They are stronger but whine more than the normal.
Old Apr 7, 2003 | 08:55 PM
Arrow
Originally posted by chesee48
i made my vote...
Nope. I am getting another set of 3.73's. I have motive now but they are shot. Need gears now before I can race on my new trans.
Old Apr 7, 2003 | 09:08 PM
Z28ROC's Avatar
Maybe just a bad set or bad install, but I shattered a set of Richmonds. And the Motives have held up for almost 3 years of abusive nitrous launches.
Old Apr 7, 2003 | 10:59 PM
Lightbulb
Yep. I was told that they were set up wrong causing abnormal wear. I will probably go with the motives again.
Old Apr 7, 2003 | 11:05 PM
Wild1's Avatar
GM Motives and 4.10s on a M6. I went with www.chrismans.com
Old Apr 7, 2003 | 11:28 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
strange
Wild one,
please shorten your sig
Old Apr 7, 2003 | 11:51 PM
Wild1's Avatar
I rarely use the sig except if it illustrates a point. In this case, these are my mods and the 4.10s work very well with this set up. I appreciate your politeness and I will continue to use it sparingly.
Old Apr 8, 2003 | 06:57 AM
IDOXLR8's Avatar
Another vote for Strange Gears.
Old Apr 8, 2003 | 07:38 AM
F-body383's Avatar
Exclamation 410's
I have GM/Motive 410's in My firebird and they rock, Loud winding though, but the strength is unreal
Old Apr 8, 2003 | 11:04 AM
Wild1's Avatar
My set howled for about 300 miles. I took it very easy and didn't do any hard launches. Also, kept it at 60 MPH for the first 300.
Now, they are quiet and smooth. I would recommend GM Motives as stated earlier. I've heard good things from Strange too! Both are quality companies.
The GM Motives are supposed to be "lapped" to smooth the edges and make them quiet.
CARiD
Apr 8, 2015 08:08 AM
greenzee28
Mar 26, 2015 09:13 AM
Nostang 96z
Sep 10, 2002 08:54 PM
