gearing?
Old Jun 16, 2008 | 11:30 PM
SS NSTAG8R's Avatar
gearing?
hey guys, hopefully this will be quick and painless, I just bought a 95 formula, The guy before me put a 12 bolt in with 373 gears. Are the factory rear end gears 373's or 343's? I'm trying to figure out if my speedo is off because of this or just from him putting in silver face gauges. Thanks a lot!
Old Jun 16, 2008 | 11:32 PM
88IROC_Z's Avatar
you can try this:
http://www.f-body.org/gears/
Old Jun 17, 2008 | 03:21 AM
Counted Out's Avatar
What kind of transmission?
Old Jun 17, 2008 | 04:18 AM
SS Joe's Avatar
If its an auto, it came with 2.73s or 3.23s. All six speed cars had 3.42s.
Old Jun 17, 2008 | 11:57 PM
SS NSTAG8R's Avatar
hey guys, thanks a lot for the help, It is an M6. So I guess that means the speedo is off from the gear change. Better get er in to re-tune for the 3.73's. Like I said, pretty simple and painless.
Old Jun 18, 2008 | 12:21 AM
TD95Z's Avatar
If you have an M6, your door code should show GU6 for 3.42 gears.
Old Jun 18, 2008 | 08:46 PM
SS NSTAG8R's Avatar
didn't really see the door code, but i'm sure it's there. Not sure what i was looking for. Another little question, like I said it is an m6, when I was under the car yesterday changing my oil, i noticed it had a "use dextron II ATF fluid only" sticking on the trans housing... do they just use the same housing for autos or manuals?
Old Jun 18, 2008 | 08:54 PM
z28camaro1090's Avatar
i would say they are 3.43's but if you have a m6 i would go with 4.11's
Old Jun 19, 2008 | 09:37 AM
SilverZConvertible's Avatar
Check the Glove for the GU code also
Old Jun 20, 2008 | 09:52 PM
Detailedprmance's Avatar
1993 pontiac trans am stock rear
I have a 1993 pontiac trans am with a stock rear wanted to know some opions about puting 373 gears inside and how long it would last
Old Jun 21, 2008 | 08:37 AM
bombebomb's Avatar
Alot of manuals also use ATF, I do not own a m6 though, but if it was me, id do what it says, maybe someone with an m6 can chime in.
You mean 3.42's
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
