Gauge install...drilling firewall
Old Sep 2, 2003 | 09:00 PM
steve10358's Avatar
3rd Gen Tech Moderator
Hi guys- I am installing boost and fuel pressure gauges in my 94 T/a.
Where in the firewall did you guys drill, and what size?
What about for the MSD dial that comes with my BTM?
Steve
Old Sep 2, 2003 | 09:11 PM
NOMAD's Avatar
Cool
I drill holes to the right (from inside) of the brake pedal on my wifes 3rd gen. I actually pulled back the carpet and drilled slowly from the inside. Just make sure it's not around your feet and under the carpet so you don't rip em out
-Shannon
Old Sep 2, 2003 | 09:13 PM
L44's Avatar
L44
You got a few options, theres the one behind the PCM on the pass side, or you can drill into the firewall on the drivers like i did, i had the dash out so everything was a little easier, i did it basically above the brake pedal i made a 0 gauge hole though so i could run alottt of stuff thru it =)
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
