Gasket type plugs with LT1 heads?
Old Mar 4, 2006 | 06:45 AM
  #16
cehan's Avatar
Re: Gasket type plugs with LT1 heads?
Originally Posted by fast 93 z
Correct....but when screwing a gasket plug in a tapered hole might change the reach when it bottoms out compared to a tapered hole with tapered plug or gasket style hole with gasket style plug.
You shouldn't be tightening them until they bottom out. The thread pitch on a 14 mm plug is almost exactly 20 tpi. If you tighten them an additional 1/2 -2/3 turn as is suggested by NGK, that equates to .025"-.033", which not going to change the reach significantly. Besides, the nose of the 5671 plug is a lot shorter than the TR55's anyway.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
