Gasket type plugs with LT1 heads?
Old Mar 2, 2006 | 09:38 PM
Cmr0z28's Avatar
I have stock heads, and purchased NGK R-5671-A7 plugs as per Lloyd Elliott's recommendation. However, they are a gasket type plug....not tapered. Will they fit or no?
Old Mar 2, 2006 | 11:02 PM
Re: Gasket type plugs with LT1 heads?
You should be using a tapered plug, AFAIK. Maybe he knows something different about it.
Old Mar 2, 2006 | 11:07 PM
Cmr0z28's Avatar
I would use the NGK R 5671-A7's on any LT1.
From his e-mail...
Old Mar 3, 2006 | 06:55 AM
cehan's Avatar
That's what I'm using. I wondered about that, but when I inspected the crush gasket closely, it appears that the gasket face is tapered. I figured that it would probably form into the tapered surface in the cylinder head. I put them in and torqued them like it said on the box (hand tight + 1/2-2/3 turn) and they seem to be working just fine.
Old Mar 3, 2006 | 06:56 AM
Bersaglieri's Avatar
I forget what Lloyd told me on the phone...whats the advantage to these again?
-Dustin-
Old Mar 3, 2006 | 07:12 AM
Javier97Z28's Avatar
Moderator
-Dustin-
Less detonation I believe?
Old Mar 3, 2006 | 07:18 AM
-Dustin-
Old Mar 3, 2006 | 08:25 AM
Cmr0z28's Avatar
They're colder plugs...he said more timing / N2O / boost before detonating.
Old Mar 3, 2006 | 08:27 AM
fast 93 z's Avatar
Putting a gasket style plug in a tappered style hole may effect the reach of the plug. I would check that first.
Old Mar 3, 2006 | 10:27 AM
cehan's Avatar
The threaded part of the R-5671-A7 plug is identical length to a TR55.
Old Mar 3, 2006 | 10:37 AM
fast 93 z's Avatar
Correct....but when screwing a gasket plug in a tapered hole might change the reach when it bottoms out compared to a tapered hole with tapered plug or gasket style hole with gasket style plug.
Old Mar 3, 2006 | 10:52 AM
Cmr0z28's Avatar
I'm gonna e-mail Lloyd a link to this thread...hopefully he can chime in.
Old Mar 3, 2006 | 03:50 PM
kyle97's Avatar
I believe the advantage is that those plugs have a recessed tip which is supposed to reduce detonation and let you run more timing.
Old Mar 3, 2006 | 05:23 PM
Cmr0z28's Avatar
Got a response from Lloyd...
I always use them on LT1's and they work great.
I would gap them .035 to .040.
Lloyd
Old Mar 3, 2006 | 06:08 PM
n2ceptor's Avatar
This is from NGK.com web site.... Not much info.....
racing plug, 14mm, 3/4" reach, 5/8" hex, gasket seat, non resistor, V-power (v-grooved center electrode)
NGK - R-5671-A7
Automotive Fitting:
We do not have an automotive fitting for this part in our database.
As for www.ngksparkplugs.com the official site to late to call to find out any info...
Technical Support
hours: 8:30am - 5:00pm Monday-Friday EST
tel: 1-877-473-6767 prompt #2
