Gasket prep?
Old Nov 25, 2007 | 03:37 PM
B-Rad420's Avatar
Gasket prep?
What all is needed for removing the old gaskets when putting on new head, intake, timing chain, etc. All I have right now is a scraper but there is still a small amount of material left. Sould I use anything else like some kind of wire attachment for a drill or brush? Thanks
Old Nov 25, 2007 | 03:46 PM
The Engineer's Avatar
I use lacquer thinner and a rag to wipe and clean the surfaces. The lacquer thinner helps soften-up remaining surface debris.
WD
Old Nov 25, 2007 | 03:52 PM
Stl94LT1's Avatar
I use a single edge razor blade.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
