Gasket matching intake, is it needed
Old Feb 11, 2006 | 12:45 PM
BMAN'S SCZ's Avatar
I have a stock intake and a gasket matched/ ported intake. Do you think there is more of a benefit running the match/ported intake. I heard that our intakes flow well already. What do you think. Will there be a noticeable difference. Thanks........John
Old Feb 11, 2006 | 01:00 PM
96capricemgr's Avatar
Re: Gasket matching intake, is it needed
The only way I would recommend playing with the intake is if it is done WITH the heads. If you make the ports on the intake larger or placed differently than in the head the transition to the smaller or stepped in head port would flow a lot worse than the unported intake.
Old Feb 11, 2006 | 02:21 PM
BMAN'S SCZ's Avatar
Thanks for the reply. I have ported AFR's so that wouldn't be a problem. I was just wondering if there is any benefit.......John
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
LT14LIFE
Feb 9, 2015 09:35 PM
thenewkid
Nov 27, 2014 09:41 AM
Snoman73
Nov 17, 2014 07:22 PM
