Gasket kit...anybody know what these are for?
Old Sep 5, 2007 | 09:33 AM
a walker's Avatar
I got the Sealed Power / Fel Pro complete gasket kit (part #260-1650) and there's a couple pieces that I don't recognize. Anybody know what they are for? The second pic is probably just some garbage that made it's way into the kit from the factory, but I want to make sure.
Old Sep 5, 2007 | 09:56 AM
97 6SPEED Z's Avatar
Smile
The items in the second picture go over your valve stems before you install your valve stem oil seals. Those little plastic "covers" prevent the ID of the valve seals from getting cut/torn during installation. Once the new seal is slipped down past the retainer grooves on the valve stem, that plastic piece is removed and moved over to help install the next seal. Got it?
Old Sep 5, 2007 | 10:49 AM
a walker's Avatar
Ah, ok. Good thing I didn't put em in the trash.
Thanks man
Anybody know where the nylon things go?
Old Sep 5, 2007 | 11:34 AM
pizzi-man's Avatar
The tube shaped plastic piece is for the oil pump to oil pump shaft. notsure about the plastic washer
Old Sep 5, 2007 | 01:18 PM
Z28SORR's Avatar
Never seen one in a kit before, but sure looks like the oil pan drain plug washer.
Old Sep 5, 2007 | 01:30 PM
a walker's Avatar
It does look like that, but this is much too big to be the oil pump shaft sleeve.
Old Sep 5, 2007 | 01:33 PM
a walker's Avatar
Yeah, I think you could be right. I just remembered that the contents are on the box... I never even thought of looking there to see what these things are for. DOH!
Old Sep 5, 2007 | 09:15 PM
a walker's Avatar
I got home from work and looked at the box. pizzi-man and Z28sorr, you were both right. The longer one is for the oil pump driveshaft, and the flat one is for the drain plug. I thought the oil pump sleeve was smaller than that, but I guess I was mistaken. You guys rock.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
