Gasket kit...anybody know what these are for?
I got the Sealed Power / Fel Pro complete gasket kit (part #260-1650) and there's a couple pieces that I don't recognize. Anybody know what they are for? The second pic is probably just some garbage that made it's way into the kit from the factory, but I want to make sure.
The items in the second picture go over your valve stems before you install your valve stem oil seals. Those little plastic "covers" prevent the ID of the valve seals from getting cut/torn during installation. Once the new seal is slipped down past the retainer grooves on the valve stem, that plastic piece is removed and moved over to help install the next seal. Got it?
I got home from work and looked at the box. pizzi-man and Z28sorr, you were both right. The longer one is for the oil pump driveshaft, and the flat one is for the drain plug. I thought the oil pump sleeve was smaller than that, but I guess I was mistaken. You guys rock.
WobblySausage
Oct 7, 2015 02:44 PM
