Gasket cleaning...
Old May 20, 2004 | 09:52 PM
Myxtreme1's Avatar
Gasket cleaning...
So how would you guys suggest cleaning the gasket left-overs from my stock exhaust gaskets? I have cleaned a little off with some 400 grit sand paper with so so luck. Any suggestions are appreciated.
Old May 20, 2004 | 10:16 PM
Spinner's Avatar
surface prep scuff wheel +dremel or air tool
Old May 20, 2004 | 10:27 PM
97WS6SCharged's Avatar
The stock exhaust gaskets are sandwiched metal. There shouldn't be anything to clean.
Old May 20, 2004 | 10:30 PM
PoorMan's Avatar
Straight edge razor blade scaper and NAPA gasket remover spray. You will only think it's clean until you try this. It even gets alot of the oil out of the pores in the metal.
Old May 21, 2004 | 06:19 AM
Myxtreme1's Avatar
Thanks guys. These may not have been the stocks. No telling.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
