Gas smell in intake? Why?
Old Jun 28, 2004 | 10:36 AM
ChickenScreamer94's Avatar
So i have this gas odor in my intake. I was checking for vacuum leaks (my car runs a little rich, evenly on both banks) and I pulled of my intake elbow to see if was cracked. Opened the TB blades and instant gas smell. Could this be from the evap stuff? I would check the injectors but it starts right up with no lag.
I also checked the vacuum at the FPR and it was holding 20 In/hg and didnt really bleed off, so does that mean my FPR is still good?
Old Jun 28, 2004 | 11:27 AM
19camaro71's Avatar
to me it sounds like you are trying to trace something that isn't really a problem, i mean your car runs good with no lag, at least thats what u said.
Without knowing how strong the smell actually is i am going to say this... Your injectors pulse, fuel goes in to the ports of the intake. Everyone i know that has an f-body says that they run rich, which leaves me to believe that all of them do run a little rich. My car runs really rich, so much that when i start it up... black smoke comes out.
Again, it sounds like you are trying to trace something that isn't there.
good luck
19camaro71
Old Jun 28, 2004 | 12:28 PM
Well, my oil smells like gas...
But it always has, even at 30k miles when I got it. Since then i have replaced the opti, plugs, wires, egr, intake gaskets, checked vacuum lines, etc. It is still there.
I know it runs rich becasue on my scanner my BLM's are at 116ish on both sides. The integrators are at 128-135ish though? I am getting pissed.
I took a freeway trip and got about 26-30ish MPG hwy, That tank was an average of 24 MPG, so maybe i am just ****...
Old Jun 28, 2004 | 12:40 PM
26-30 mpg on the freeway is prertty darn good for an auto, IMO. Send a data log to a tuner and get a tune, if you want changes.
Lt4Z2897
Mar 26, 2015 03:02 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
birdblack
Dec 30, 2014 06:59 PM
simple
Aug 11, 2002 11:56 AM
