gas odor
Old Feb 23, 2004 | 09:05 PM
raz0r6's Avatar
gas odor
ok so when i fill the tank up full it smells like gas on the inside of my car anyone ever had this problem if so tell me what ya did to fix it
thanks
Kyle
Old Feb 23, 2004 | 09:10 PM
PatriotTA's Avatar
Probably some sort of malfuction with your EVAP system. check that little black box on the passenger side of your intake manifold and make sure there are two vacuum lines connected to it. One line (top one, IIRC) should go to the throttle body. The bottom should be the 3rd line that comes in with your 2 fuel lines. Also, check out our charcoal canister, and make sure 2 lines are conncected to it (remove the access panel in your drivers side rear wheelwell).
Old Feb 23, 2004 | 09:13 PM
LT1Noob's Avatar
also, it could be bad O2 sensors causing you to run rich. Does your back bumper have any carbon deposits on it?
Old Feb 23, 2004 | 09:37 PM
raz0r6's Avatar
no i have no carbon build up and i have a v-6 if that helps out a bit i already have this posted in the V-6 section and i was wondering if any of you z28 SS guys new the problem would it be the seal around the fuel pump on top of the gas tank its only when i fill the car up to the top a (FULL Tank)
Kyle
Old Feb 23, 2004 | 10:02 PM
1.8ttolt1's Avatar
charcoal canister
Old Feb 23, 2004 | 10:12 PM
phil94-T/A's Avatar
Charcoal Canister
Phil
Old Feb 24, 2004 | 04:53 AM
raz0r6's Avatar
whats a charcoal canister and how hard is it to replace and where is it loacated anybuddy have any idea how much one might cost????
Old Feb 24, 2004 | 02:02 PM
raz0r6's Avatar
ok you guys say it is a charcoal canister can some one go into deeper into explannig what this means. and could it be anything else this smell only happens when i fill the tank to the top.
anyone??????
Old Feb 24, 2004 | 02:25 PM
1.8ttolt1's Avatar
http://web.camaross.com/forums/searc...der=descending
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
