Gain from power steering removal?
Just wondering if there would be any performance gains from removing the power steering pump? I've already removed the AC, and am relocating the alternator..Anybody?
You might see some small gains by removing it and freeing up some of the parasitic loss that the engine accessories present. You could get the same effect by just removing your serpentine belt prior to your runs on the drag strip and still keep a functional power steering system.
It sucks scooting around in tight slow moving areas with no power steering! I had a car with out it before and you get used to it pretty quick but you cant fly out of parking spaces because it takes too long to turn the wheel after backing up.
Re: Gain from power steering removal?
Not sure how this could be possible? Assuming the pump has only the parasitic power loss mentioned above as there should be no load on pump unless you are turning the wheels. I would imagine large overall time\HP gain for an autoX car that is continually turning, but for a drag car I wouldn't imagine anything more than 1-2hp for parasitic loss max. This is operating under the assumption the pump is indeed in bypass when not actively turning the wheels.
stockssn2o
May 25, 2015 08:54 AM
mspennyhughes
Mar 1, 2015 03:50 PM
SMO Q
Feb 11, 2015 07:13 AM
