G2 Cold Air Kit any good???
Old Jun 28, 2005 | 03:27 PM
jamilz28's Avatar
is the G2 Cold Air Kit any good i am gonna buy it from someone for cheap
http://www.lmperformance.com/4233/2.html
Old Jun 28, 2005 | 03:33 PM
PurePonyPounder's Avatar
Re: G2 Cold Air Kit any good???
I wouldn't even bother with a LT1 specific cold air, Pound per Pound you are better off converting to an LS1 set-up than the traditional 90' LT1 intake. A couple of folks have completed this mod, run a quick search.
Old Jun 28, 2005 | 03:37 PM
jamilz28's Avatar
i dont want any home made stuff on my car
Old Jun 28, 2005 | 03:42 PM
LUDA0840's Avatar
it looks like the stock setup for the lt1.
Old Jun 28, 2005 | 03:49 PM
jamilz28's Avatar
thats why i posted it i didnt know if it would work good
Old Jun 28, 2005 | 03:50 PM
turbo_Z's Avatar
The larger filter is what you are after. That G2 setup utilizes the stock filter size so IMO there are better CAIs out there. And it doesnt even relocate the filter further away from the motor like the FIPK or moroso do.
Old Jun 28, 2005 | 03:54 PM
jamilz28's Avatar
the one i am getting dose not come with a filter i am gonna get a k&n cone filter
Old Jun 28, 2005 | 03:59 PM
moparman's Avatar
It doesn't use a cone filter.
Old Jun 28, 2005 | 04:05 PM
jamilz28's Avatar
but you can use one
Old Oct 24, 2006 | 09:19 PM
z275plus's Avatar
G2 Cold air kit any good
I have the G2 with the K&N filter on the end,was a perfect fit.Not sure of the hosepower gain vs the fipk but solved the problem and the fipk filter falling off,pain in the rear.
Car still appear to run just as strong with the G2 as it did with the fipk.The stock filter box was the restriction with the G2 as far as I could tell.
When I had the stock box on,which was cut open the engine appeared to be under a strain but when I put the K&N filter on,it seem to run and pull like it use to when I had the fipk cold air kit on.
I wonder how much of a difference in hp between the G2 with the K&N filter and the fipk cold air kit with the same filter?
I wanted to change over to the ls1 style cai but could not find a good write up on what all needed to be changed.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Britbilly
Jan 7, 2015 08:49 PM
thenewkid
Nov 27, 2014 09:41 AM
