Fuseable wires by power junction???
Old May 23, 2006 | 02:40 PM
CDE's Avatar
CDE
I was wondering where the black wires that tie into the red power junction box on the pass side fender go to. I have a grounded wire messing things up but with out tearing the car apart and the taking off the plastic 1" wireloom I cant tell where it goes too. I heads down the fender and goes in front of the water resevoir then in front of the radiator and out of sight. I assumed it is going to the relay box on the drivers side of the car, is this correct??
Clint
Old May 23, 2006 | 10:52 PM
Re: Fuseable wires by power junction???
They go lots of places...mostly to the fuse boxes in the engine compartment and in the dash.
Old May 23, 2006 | 11:51 PM
CDE's Avatar
CDE
Ok Thanks, I will try to trace it around somehow.
Thank you
Clint
Old May 24, 2006 | 06:50 AM
If you have a constant problem, you can just check fuses to see what is being affected. Perhaps then, you can isolate the fusible links from the terminal and use a meter or test light to determine which one it is.
mr28
Apr 20, 2016 05:44 PM
mr28
Nov 23, 2014 11:11 AM
Jul 4, 2005 05:00 PM
Omega9
Aug 2, 2002 12:33 AM
