Fuse Question
Old Jul 10, 2003 | 12:00 AM
RealQuick's Avatar
Fuse Question
I am looking for the headlight fuse and the power windows fuse (driver's side if they are seperate). Anyone know?
Old Jul 10, 2003 | 06:15 AM
Mtrhds94Z's Avatar
There is no headlight fuse..
Thre's a fusible link for them..
Old Jul 10, 2003 | 06:32 AM
RealQuick's Avatar
I need to hook up power for my lamp on the Fuel Pressure Gauge. I want it to come on with the lights. What I mean is, whenmy gauge cluster turns on, then I want the elect. fuel gauge to light up too. Is there a fuse for the dash lights?
Old Jul 10, 2003 | 07:18 AM
scoobysnax83's Avatar
Theres a wire for the stock radio that does it. Or you could just go straight for the switch. Depending on where you mount it. It should be close to either one of those.
Old Jul 10, 2003 | 07:28 AM
RealQuick's Avatar
The problem is I cant get at the switch. I started taking the bottom of the dash apart, but damn! Those wires are tied together tight and I cant really get up in there. I would prefer the fuse panel for easy access
Old Jul 10, 2003 | 07:41 AM
RealQuick's Avatar
What about running off the dimmer switch? What color wire do I tap into?
Old Jul 10, 2003 | 08:03 AM
BlownF1's Avatar
Best place is as suggested...the stock radio harness has a gray (I think, it's been awhile) wire that comes on with the lights, and dims with the dashboard dimmer switch.
Old Jul 10, 2003 | 09:13 AM
RealQuick's Avatar
ok, cool. The reason I wanted to go near fuse panel so I can run a shorter wire to dimmer. IF not, thats ok. Thanks for the help guys.
Old Jul 10, 2003 | 09:31 AM
BlownF1's Avatar
I hear ya, it's just not very accessible up there. Been there, tried that myself and I've got small hands, still couldn't get it. The radio one is a 10 minute job...
Old Jul 10, 2003 | 11:07 AM
Old Jul 10, 2003 | 11:12 AM
RealQuick's Avatar
Originally posted by scoobysnax83
Your right.
Old Jul 10, 2003 | 11:26 AM
Your right.
Well, I wasn't going for all that, but it sure brightened my day, lol.
jayvar
Feb 2, 2015 10:00 PM
fpete1992
Dec 11, 2014 03:51 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
CLEAR
Aug 30, 2002 07:49 PM
$hawn
Aug 17, 2002 04:37 PM
