Funny Rev When you stomp on it
Old Apr 29, 2003 | 11:43 PM
fbird95's Avatar
I have a manual, if i stomp on the gas the tach jumps a little bit before the car starts to take off. I have seen this in autoomatic cars. Is this normal for a manual. Thanks for the replies
Old Apr 29, 2003 | 11:47 PM
IrocManiac's Avatar
Thats kinda wierd, usually I'd say clutch is slipping, is the rpm's coming back down or do htey continue to float upward?
Old Apr 30, 2003 | 12:21 AM
fbird95's Avatar
they stay up for about 2 seconds than the when the car speeds up it stays there. Its only under WOT all other times there is no problem . If i stomp on it, the rpms go up quick, then unless i leave it at WOT they come down right away. I think the car had a new clutch about 20,000 miles ago, its done this since i got it 2 years ago.
Old Apr 30, 2003 | 12:23 AM
IrocManiac's Avatar
Still sounds like a pressure plate or clutch problem...
Old Apr 30, 2003 | 12:34 AM
fbird95's Avatar
thanks, for the help . I'm not going to worry about it, unitll it fails.
Old May 2, 2003 | 10:47 AM
fbird95's Avatar
Should have knocked on wood. It was both the clutch disk and the pressure plate failing. New clutch is in now so its all good.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
asilomar244
Jul 12, 2015 05:53 AM
