Full floating piston pin retainer installation: how do you get them in?
Old Jul 7, 2007 | 02:21 PM
blue's Avatar
The pins go in easy of course, but the lock ring type retainers to hold them don't go in easy, or any other way that I can see. How do you get them in? They're like these http://store.summitracing.com/egnsea...115+4294808882. But summit doesn't have any tool for installation that I can find.
Old Jul 7, 2007 | 02:29 PM
wrd1972's Avatar
They are very stiff and difficult to install. I used needle nose pliers and a flat tip screw driver. The trick is to insert one end of the clip and work the rest of the clip in a circular manner. Easier said then done. Just give it a try and try not to gouge the hole or the piston surface incase you "slip up".
No special tools needed.
blue's Avatar
Apparently you get them in...with great difficulty.
http://www.ls1tech.com/forums/showthread.php?t=178671
Old Jul 7, 2007 | 02:47 PM
lethal93ta's Avatar
there not that bad once you get a couple of them in, my pistons are doubled up 4 sprial locks on each piston, you can stretch them some, I just used a straight pick to work them in a circle.
Old Jul 7, 2007 | 05:40 PM
blue's Avatar
Got 'em. Thanks for the replies. A little over two hours. I stretched them then used fingers and a little flat blade screwdriver. Getting the old ones out was almost as much trouble. Getting the old ones out might actually be more trouble if you were re-using the pistons and were trying not to scratch them.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
1963SS
Feb 6, 2015 10:05 AM
NewsBot
Jan 23, 2015 01:10 PM
