Full bolt on
Old Oct 13, 2005 | 02:38 PM
Honda Hunter's Avatar
Full bolt on
What exactly is a full bolt on car? I hear the term "full bolt on" tossed around alot but what exactlly is full bolt on's, what mods?
Old Oct 13, 2005 | 03:47 PM
stereomandan's Avatar
Re: Full bolt on
Typically, it’s anything that is bolted to the car/engine to produce more HP, that doesn’t require the removal of the intake or heads or bottom end. Forced air or nitrous is not included either (SC or turbo’s) So….
Headers
Catback exhaust
CAI
Different MAF
Throttle Body
Intake Elbow
Electric Water pump
Pulleys
1.6 RR’s
PCM Tuning
Wires
Plugs
Ignition
Knock Module
Also, you can have different rear gears, a new rear axle, suspension, chassis mods, and still be considered bolt-on.
I’m sure I’m missing some…
Dan
Old Oct 13, 2005 | 04:44 PM
ibanez6rg's Avatar
Re: Full bolt on
A lot of people consider a S/C a bolt-on.
Old Oct 13, 2005 | 05:55 PM
97s10ondubs's Avatar
Re: Full bolt on
Ive heard some people say "if it touches oil its not a bolt-on" so that could take 1.6rr's out. Even though they do just technically bolt on.
Old Oct 13, 2005 | 06:37 PM
jkipp84's Avatar
Re: Full bolt on
This is my understanding as well...
Old Oct 14, 2005 | 03:19 AM
2000GTP's Avatar
Re: Full bolt on
It doesn't make much sense, huh??
Old Oct 14, 2005 | 06:09 AM
Jameslt1TA's Avatar
Re: Full bolt on
Ya but a new set of heads will just "bolt on" to the engine.
Old Oct 14, 2005 | 07:11 AM
Re: Full bolt on
ok im sticking to if it touches oil theory , how bout you cant remove the valve covers?
Old Oct 14, 2005 | 07:34 AM
ibanez6rg's Avatar
Re: Full bolt on
Sweet, so we're assuming S/C as a bolt-on?
Old Oct 14, 2005 | 07:40 AM
Re: Full bolt on
lol I guess it all depends on which s/c. A Vortech under the rules listed wouldnt be were as a roots/screw or procharger depending on the model would be.
Old Oct 14, 2005 | 07:42 AM
Re: Full bolt on
s/c need to be tapped for oil correct? or they are self-contained with OIL
Old Oct 14, 2005 | 08:01 AM
CustomSSI's Avatar
Re: Full bolt on
ATI makes someself contained ones, but they still use oil.............
Josh
Old Oct 14, 2005 | 08:04 AM
Re: Full bolt on
Josh
But not the engine oil. I still dont think a s/c is bolt on.
Old Oct 14, 2005 | 08:20 AM
Re: Full bolt on
definately not...
Old Oct 14, 2005 | 11:15 AM
Tekprodave's Avatar
Re: Full bolt on
It is confusing but let me try to clarify. A bolton mod is not a power adder. They are basically designed to free up horsepower that is already there. Power adders are Superchargers, turbos, and nitrous. A bolton cannnot include engine modification with the exception of rocker arms. So basically you cannot separate the heads from the block. Full bolt on means you have most or all the bolton modifications without doing a power adder and without reworking the motor. Make sense?
