fule pump goes bad, can I put inline pump??
my fuel pump its going bad, and I dint want to install the new one in the tank because of all the problems with removing the tank etc. So I was wondering is I can put an inline fuel pump and leave the ole on intact..but I dont know is this setup will be help me..
Re: fule pump goes bad, can I put inline pump??
What problems have you heard about replacing the in-tank pump. If you use this guide I made, you do not need to drop the tank.
You will need a new in-tank pump, unfortunatley. Why not take the time and upgrade to a Racetronix pump and harness kit?
